What would be the setup for the Fujitsu Scansnap scanner with workflow? I had no problem with DevonThink Pro, but I’m not satisfied with my poor work flow for EF.
I recommend setting the ScanSnap to save its files into EagleFiler’s “To Import” folder.
That’s what I tried but I can’t import into EF and the only thing I can do is drag and drop?
What do you mean by “can’t import"? When you (or ScanSnap) puts a file in the “To Import” folder, EagleFiler (if it’s open, or the next time you open that library) will automatically import it. There’s no need to drag and drop.
