A variation on a theme, this script prompts the user to enter some words that will be appended to the names of the selected records.
use AppleScript version "2.4" -- Yosemite (10.10) or later
use scripting additions
-- Script that appends new keywords to filenames
-- V1 dated 25th November 2020 by Skids
-- Test before use and USE at OWN risk
-- e.g. File : "My great File Name.pdf" is renamed "My-great-File-Name-.pdf"
set tDialog to display dialog "Please enter new Key Words." default answer "" with icon note buttons {"Cancel", "Continue"} default button "Continue"
--Set tNewKeyWords to display dialog "Please enter new Key Words." default answer "" with icon note buttons {"Cancel", "Continue"} default button "Continue"
if tDialog = "" then return
set tNewKeyWords to the text returned of tDialog
tell application "EagleFiler"
set _records to selected records of browser window 1
set tMyDelim to "-" -- change this value to change delimiter used
set tOriginalName to _record's basename
set tNewName to tOriginalName & tNewKeyWords & tMyDelim
set tNewName to my ReplaceText(" ", tMyDelim, tNewName) -- replace spaces
set tNewName to my ReplaceText("_", tMyDelim, tNewName) -- replace underscore
set tNewName to my ReplaceText(".", tMyDelim, tNewName) -- replace points
-- now remove multiple repeats of the delimiter
set tCounter to 0
repeat until tCounter > 9
set tCounter to tCounter + 1
set tCleanName to my ReplaceText(tMyDelim & tMyDelim, tMyDelim, tNewName)
if tNewName = tCleanName then
exit repeat
else
set tNewName to tCleanName
end if
end repeat
set _record's basename to tNewName
end repeat
end tell
on ReplaceText(find, replace, subject)
set prevTIDs to text item delimiters of AppleScript
set text item delimiters of AppleScript to find
set subject to text items of subject
set text item delimiters of AppleScript to replace
set subject to "" & subject
set text item delimiters of AppleScript to prevTIDs
return subject
end ReplaceText
