Hello all,
I’m not sure if I ever posted this script. It is similar to my Reading List script but pulls links directly from open iCloud tabs.
As with the Reading List script, I saved this script as an app and gave it elevated permissions: Security & Privacy -> Privacy settings -> Automation and Full Disk Access.
To use this script, you will want to modify the first line of code to include the names of all of your apple devices:
set theDeviceChoices to {"All", "iPadPro11", "iPadPro13", "iPhoneMini", "MacBookPro", "MacBookAir"}
On a Mac, find the name by navigating to: System Preferences -> Sharing -> Computer Name. On an iOS device: Settings -> General -> About -> Name. I don’t use spaces in my device names, so I’m not sure if that would cause any errors.
-- import-safari-icloud-tabs
-- Modified From:
http://c-command.com/scripts/eaglefiler/import-safari-tabs
https://workentin.wordpress.com/2016/01/10/automatically-open-all-reading-list-items/
https://discussions.apple.com/message/28304986#28304986
http://stackoverflow.com/questions/11706171/how-to-open-a-new-window-and-multiple-urls-in-safari-with-apple-script
https://gist.github.com/edenwaith/2213a764ccb091d6a03989f238efb63f
https://developer.apple.com/library/content/documentation/LanguagesUtilities/Conceptual/MacAutomationScriptingGuide/ManipulateListsofItems.html
https://discussions.apple.com/thread/6730717?start=0&tstart=0
https://developer.apple.com/library/content/documentation/AppleScript/Conceptual/AppleScriptLangGuide/reference/ASLR_operators.html
https://stackoverflow.com/questions/10064849/read-textfile-into-list-in-applescript
https://developer.apple.com/library/content/documentation/LanguagesUtilities/Conceptual/MacAutomationScriptingGuide/CallCommandLineUtilities.html
-- Last Modified: 2020-07-15
set theFavoriteDevice to choose from list theDeviceChoices with prompt "Import Safari iCloud Tabs from selected device:" default items {"All"}
if theFavoriteDevice = {"All"} then
set theQuery to "SELECT url FROM cloud_tabs"
else if theFavoriteDevice is false then
error number -128
else
FROM cloud_tabs
WHERE device_uuid = (
SELECT device_uuid
FROM cloud_tab_devices
WHERE device_name = '" & theFavoriteDevice & "')"
end if
set theURLs to {}
set theURLs to paragraphs of (do shell script "sqlite3 ~/Library/Safari/CloudTabs.db " & quoted form of theQuery)
-- Get the length of the URL list
set listSize to (count of theURLs)
-- Script activates Safari
activate application "Safari"
tell application "Safari"
-- This is the main loop
-- Loop opens as many new windows each with 12 tabs as necessary
-- Found that importing more than 12 tabs in EagleFiler can sometimes fail unexpectedly
set i to 1
repeat until i is greater than listSize
if i is greater than listSize then
exit repeat
else
-- Opens a new window with one URL
set {firstURL} to {item i of theURLs}
make new document at end of documents with properties {URL:firstURL}
set i to i + 1
end if
repeat with j from 1 to 11
exit repeat
else
-- Opens additional tabs (up to total of 12) in the new Window
tell window 1
set {theURL} to {item i of theURLs}
make new tab at end of tabs with properties {URL:theURL}
end tell
set i to i + 1
end if
end repeat
end repeat
end tell
-- Open a dialog box to allow tab trimming before import
-- Also acts as a delay to allow URLs to open
set answer to ""
repeat while answer is equal to ""
display dialog "Check that all Safari tabs have loaded. Close any tabs that you do not want to import to EagleFiler." buttons {"Cancel", "Continue"} default button "Continue" cancel button "Cancel"
set answer to button returned of result
end repeat
-- Script activates EagleFiler
activate application "EagleFiler"
-- Import to EagleFiler one window at a time
set windowList to (every window whose visible is true)
repeat with windowVariable in windowList
set _urls to URL of every tab of windowVariable
tell application "EagleFiler"
import URLs _urls
end tell
end repeat
end tell
