Script to set title
I’m trying to replicate a facility in DevonThink that I miss in EF: the ability to highlight a string in a library document and set it as the title of the library record ('Set Title As…" in DT).
But I’m not much of a scripter. The script below works most of the time. I’m sure several Forum users could do this a lot better.
The ‘clean up’ sub-routine eliminates CRs and multiple spaces from the titles of PDF files.
-- EagleFiler (v. 1.2) Script
-- Set the Title of the currently selected record
-- to the string highlighted in the record viewer
-- No rights claimed. Your mileage may vary.
---  Replace non-alphanum and non-punctuation chrs
---  on clipboard with spaces and concatenate
on cleanup()
	set myScript to ("usr/bin/pbpaste |  tr -Csu ':alnum:]:punct:]' ' ' | pbcopy")
	do shell script (myScript)
end cleanup
---  Title string should be selected in the viewer
---  or in any frontmost window before running.
---  Will set the Title of all records higlighted
---  in the library window; selecting just one
---  record is recommended ;-)
tell application "EagleFiler"
	set the clipboard to ""
	tell application "System Events"
		keystroke "c" using command down
	end tell
	tell me to cleanup()
	set newClip to the clipboard -- as text
	set theRecords to the selected records of browser window 1
	repeat with theRecord in theRecords
		set theRecord's title to newClip
	end repeat
end tell
-- ends
Cool! I’ve been planning to add this as a built-in feature, but this should tide people over. Beware that running the script will clobber the clipboard contents.
Yes… silly of me. I use JumpCut so I didn’t think about that (wish JumpCut could be scripted). There’s an easy fix that takes advantage of the un-restricted (except by memory) size of a temporary Applescript variable to suck up the clipboard contents:
-- www.petergallagher.com.au
---  with spaces and concatenate
on cleanup()
end cleanup
---  String should be selected in the viewer
---  or in any frontmost window.
---  in the library window; selecting just one is
---  recommended ;-)
	-- save the clipboard
	set oldClip to the clipboard
	end tell
	end repeat
	set the clipboard to oldClip
end tell
-- ends
This is awesome. Thanks so much.
:slight_smile:
EagleFiler 1.4 has this built into its contextual menus.
