Scrolling pdf documents
Hi,
I can’t seem to scroll through pdf files using the scrollbar, only using the scroll wheel on the mouse. I can only scroll inside the actual page, but not to the next. Am I missing something?
Markus
Is the problem that you don’t see a scrollbar or that it doesn’t work? If the former, you may need to zoom in (so that it isn’t locked to showing a full page that doesn’t need scrolling) or Control-click and set it to Continuous mode (to show more than one page at a time).
Thanx! It wasn’t set to continuous mode, didn’t find it!
