Searching in EagleFiler is very robust and amazingly fast. When searching for something in an RTF document, you can use the Find Next (Cmd-G) to find the next occurrence. In a PDF, that option is grayed out - any possibility of implementing this in PDF’s? Thanks.
EagleFiler 1.4 will support using the Find panel commands in PDF views.
EagleFiler 1.4 adds support for doing finds within PDFs and Web archives.
