Is is possible to search the trash in EF?
I may have deleted a record with an accidental key swipe and wanted to retrieve it if in fact it was gone. So I open the trash and tried to search with the tags I had used when I was searching the Records. But the search covered all the Records, not just Trash. Is there a way to look through the trash using tags (Or from, or title, etc?)
When you have Records selected, it will search everything but the Trash. When you have Trash selected, it will search only the Trash.
You can do a Tags or From or Title search with Trash selected, and it will search for those within the Trash.
That doesn’t seem to be happening.
Here are two screen shots.
No 1 shows that in a search of Records there are 182 records tagged “stopping.
No 2 shows that when I try to search Trash for stopping, it retrieves all 182 records after searching Records.
What am I doing wrong?
It looks like maybe you need to uncheck Always Search All Records in the search menu.
Forgot about that!
Sorry!
