I select my Gmail inbox, and then, when I click on filter now, nothing happens.
There is no entry in the log that I can see that indicates anything at all happened. It would really help if I could filter an inbox and get rid of all the already trained spam that had previously arrived and is sitting there unread. Please help.
Thanks!
It is not necessary to select the inbox in Select Mailboxes to Filter if you have Check inboxes for new messages not sent to Mail extension selected. Do you have filtering enabled in the Setup tab of SpamSieve’s settings? If so, it should be filtering automatically, without the need to click Filter Now.
If it’s enabled but nothing seems to be happening, you can enable additional diagnostics by clicking this link. They will then show up via Help ‣ Open Error Log or if you use the Save Diagnostic Report command in the Help menu and send us the report file, as described here.
Hi Michael,
Enable spam filtering using Mail extension is checked.
Check inboxes for new messages not sent to Mail extension is checked.
SpamSeive has Full Disk Access.
It could be me; I’m sure you’ll let me know!
Thanks
Les
Here’s the error log via copy n paste:
2024-01-23 22:40:26.041 [com.c-command.SpamSieve] launchctl (
unload,
"/Users/miniles/Library/LaunchAgents/com.c-command.SpamSieve.LaunchAgent.plist"
): Unload failed: 5: Input/output error
Try running `launchctl bootout` as root for richer errors.
CoreData: error: Failed to clone external data reference from /Users/miniles/Library/Application Support/SpamSieve/Log.spamsieve-logd/Log 2024-01.spamsieve-log/V2/.Log 2024-01_SUPPORT/_EXTERNAL_DATA/FAA414CA-3FCD-4662-8383-F8E467EE167E.interim to /var/folders/72/ldr2n3kn4s9_ll9m9vsgtrbh0000gn/T/.LINKS/2B38FB72-2300-482B-B1DB-FC7D45BB1A1C/FAA414CA-3FCD-4662-8383-F8E467EE167E_0x6000006600a0 error: Error Domain=NSCocoaErrorDomain Code=4 "The file “FAA414CA-3FCD-4662-8383-F8E467EE167E.interim” doesn’t exist." UserInfo={NSSourceFilePathErrorKey=/Users/miniles/Library/Application Support/SpamSieve/Log.spamsieve-logd/Log 2024-01.spamsieve-log/V2/.Log 2024-01_SUPPORT/_EXTERNAL_DATA/FAA414CA-3FCD-4662-8383-F8E467EE167E.interim, NSUserStringVariant=(
Copy
), NSDestinationFilePath=/var/folders/72/ldr2n3kn4s9_ll9m9vsgtrbh0000gn/T/.LINKS/2B38FB72-2300-482B-B1DB-FC7D45BB1A1C/FAA414CA-3FCD-4662-8383-F8E467EE167E_0x6000006600a0, NSFilePath=/Users/miniles/Library/Application Support/SpamSieve/Log.spamsieve-logd/Log 2024-01.spamsieve-log/V2/.Log 2024-01_SUPPORT/_EXTERNAL_DATA/FAA414CA-3FCD-4662-8383-F8E467EE167E.interim, NSUnderlyingError=0x6000029700c0 {Error Domain=NSPOSIXErrorDomain Code=2 "No such file or directory"}}
CoreData: error: Failed to clone external data reference from /Users/miniles/Library/Application Support/SpamSieve/Corpus.spamsieve-corpus/Messages.spamsieve-messages/V2/.Messages_SUPPORT/_EXTERNAL_DATA/799C6AA9-0055-4454-A408-A377B53076D7.interim to /var/folders/72/ldr2n3kn4s9_ll9m9vsgtrbh0000gn/T/.LINKS/50AA588F-9B84-4847-805B-8181C3B50722/799C6AA9-0055-4454-A408-A377B53076D7_0x600000668050 error: Error Domain=NSCocoaErrorDomain Code=4 "The file “799C6AA9-0055-4454-A408-A377B53076D7.interim” doesn’t exist." UserInfo={NSSourceFilePathErrorKey=/Users/miniles/Library/Application Support/SpamSieve/Corpus.spamsieve-corpus/Messages.spamsieve-messages/V2/.Messages_SUPPORT/_EXTERNAL_DATA/799C6AA9-0055-4454-A408-A377B53076D7.interim, NSUserStringVariant=(
Copy
), NSDestinationFilePath=/var/folders/72/ldr2n3kn4s9_ll9m9vsgtrbh0000gn/T/.LINKS/50AA588F-9B84-4847-805B-8181C3B50722/799C6AA9-0055-4454-A408-A377B53076D7_0x600000668050, NSFilePath=/Users/miniles/Library/Application Support/SpamSieve/Corpus.spamsieve-corpus/Messages.spamsieve-messages/V2/.Messages_SUPPORT/_EXTERNAL_DATA/799C6AA9-0055-4454-A408-A377B53076D7.interim, NSUnderlyingError=0x6000029695c0 {Error Domain=NSPOSIXErrorDomain Code=2 "No such file or directory"}}
CoreData: error: Failed to clone external data reference from /Users/miniles/Library/Application Support/SpamSieve/Log.spamsieve-logd/Log 2024-01.spamsieve-log/V2/.Log 2024-01_SUPPORT/_EXTERNAL_DATA/D44DD08D-C8F5-4C77-9753-83A8D2E7C661.interim to /var/folders/72/ldr2n3kn4s9_ll9m9vsgtrbh0000gn/T/.LINKS/2B38FB72-2300-482B-B1DB-FC7D45BB1A1C/D44DD08D-C8F5-4C77-9753-83A8D2E7C661_0x600000597d40 error: Error Domain=NSCocoaErrorDomain Code=4 "The file “D44DD08D-C8F5-4C77-9753-83A8D2E7C661.interim” doesn’t exist." UserInfo={NSSourceFilePathErrorKey=/Users/miniles/Library/Application Support/SpamSieve/Log.spamsieve-logd/Log 2024-01.spamsieve-log/V2/.Log 2024-01_SUPPORT/_EXTERNAL_DATA/D44DD08D-C8F5-4C77-9753-83A8D2E7C661.interim, NSUserStringVariant=(
Copy
), NSDestinationFilePath=/var/folders/72/ldr2n3kn4s9_ll9m9vsgtrbh0000gn/T/.LINKS/2B38FB72-2300-482B-B1DB-FC7D45BB1A1C/D44DD08D-C8F5-4C77-9753-83A8D2E7C661_0x600000597d40, NSFilePath=/Users/miniles/Library/Application Support/SpamSieve/Log.spamsieve-logd/Log 2024-01.spamsieve-log/V2/.Log 2024-01_SUPPORT/_EXTERNAL_DATA/D44DD08D-C8F5-4C77-9753-83A8D2E7C661.interim, NSUnderlyingError=0x6000029fe100 {Error Domain=NSPOSIXErrorDomain Code=2 "No such file or directory"}}
CoreData: error: Failed to clone external data reference from /Users/miniles/Library/Application Support/SpamSieve/Log.spamsieve-logd/Log 2024-01.spamsieve-log/V2/.Log 2024-01_SUPPORT/_EXTERNAL_DATA/8C3C3387-3361-4E68-A562-0AFF4562B12B.interim to /var/folders/72/ldr2n3kn4s9_ll9m9vsgtrbh0000gn/T/.LINKS/2B38FB72-2300-482B-B1DB-FC7D45BB1A1C/8C3C3387-3361-4E68-A562-0AFF4562B12B_0x6000005979d0 error: Error Domain=NSCocoaErrorDomain Code=4 "The file “8C3C3387-3361-4E68-A562-0AFF4562B12B.interim” doesn’t exist." UserInfo={NSSourceFilePathErrorKey=/Users/miniles/Library/Application Support/SpamSieve/Log.spamsieve-logd/Log 2024-01.spamsieve-log/V2/.Log 2024-01_SUPPORT/_EXTERNAL_DATA/8C3C3387-3361-4E68-A562-0AFF4562B12B.interim, NSUserStringVariant=(
Copy
), NSDestinationFilePath=/var/folders/72/ldr2n3kn4s9_ll9m9vsgtrbh0000gn/T/.LINKS/2B38FB72-2300-482B-B1DB-FC7D45BB1A1C/8C3C3387-3361-4E68-A562-0AFF4562B12B_0x6000005979d0, NSFilePath=/Users/miniles/Library/Application Support/SpamSieve/Log.spamsieve-logd/Log 2024-01.spamsieve-log/V2/.Log 2024-01_SUPPORT/_EXTERNAL_DATA/8C3C3387-3361-4E68-A562-0AFF4562B12B.interim, NSUnderlyingError=0x6000029fe490 {Error Domain=NSPOSIXErrorDomain Code=2 "No such file or directory"}}
2024-01-25 00:09:18.394 SpamSieve[27099:1928431] _TIPropertyValueIsValid called with 14 on nil context!
2024-01-25 00:09:18.394 SpamSieve[27099:1928431] imkxpc_getApplicationProperty:reply: called with incorrect property value 14, bailing.
2024-01-25 00:09:18.394 SpamSieve[27099:1928431] Text input context does not respond to _valueForTIProperty:
2024-01-25 00:09:18.396 SpamSieve[27099:1928431] _TIPropertyValueIsValid called with 10 on nil context!
2024-01-25 00:09:18.396 SpamSieve[27099:1928431] imkxpc_setApplicationProperty:value:reply: called with incorrect property value 10, bailing.
CoreData: debug: PostSaveMaintenance: fileSize 9706752 greater than prune threshold
CoreData: annotation: PostSaveMaintenance: wal_checkpoint(TRUNCATE)
CoreData: debug: PostSaveMaintenance: fileSize 10448352 greater than prune threshold
CoreData: debug: PostSaveMaintenance: fileSize 11400072 greater than prune threshold
CoreData: debug: PostSaveMaintenance: fileSize 8511952 greater than prune threshold
2024-01-25 21:01:32.964 [com.c-command.SpamSieve] [LogMailFilterer] Call AppleScript subroutine listInboxesToCheck: 0.46s
2024-01-25 21:01:32.965 [com.c-command.SpamSieve] [LogMailFilterer] Filter mailboxURLs: [mailbox:/INBOX?accountName=iCloud, mailbox:/INBOX?accountName=Gmail, mailbox:/INBOX?accountName=Lia-Newmedia]
2024-01-25 21:01:32.966 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: iCloud ‣ INBOX
2024-01-25 21:01:32.966 [com.c-command.SpamSieve] [LogMailFilterer] Filter mailboxURLs: []
2024-01-25 21:01:32.980 [com.c-command.SpamSieve] [LogMailFilterer] Call AppleScript subroutine accountDirectories: 0.01s
2024-01-25 21:01:32.982 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 0
2024-01-25 21:01:32.982 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages in iCloud ‣ INBOX
2024-01-25 21:01:32.982 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in iCloud ‣ INBOX
2024-01-25 21:01:32.982 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: Gmail ‣ INBOX
2024-01-25 21:01:32.985 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 2
2024-01-25 21:01:32.985 [com.c-command.SpamSieve] [LogMailFilterer] Found 2 unread messages in Gmail ‣ INBOX
2024-01-25 21:01:32.986 [com.c-command.SpamSieve] [LogMailFilterer] Already filtered IDs: 2
2024-01-25 21:01:32.986 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in Gmail ‣ INBOX
2024-01-25 21:01:32.986 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: Lia-Newmedia ‣ INBOX
2024-01-25 21:01:32.987 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 0
2024-01-25 21:01:32.987 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages in Lia-Newmedia ‣ INBOX
2024-01-25 21:01:32.987 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in Lia-Newmedia ‣ INBOX
2024-01-25 21:02:03.911 [com.c-command.SpamSieve] [LogMailFilterer] Filter mailboxURLs: [mailbox:/INBOX?accountName=iCloud, mailbox:/INBOX?accountName=Gmail, mailbox:/INBOX?accountName=Lia-Newmedia]
2024-01-25 21:02:03.912 [com.c-command.SpamSieve] [LogMailFilterer] Filter mailboxURLs: []
2024-01-25 21:02:03.913 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: iCloud ‣ INBOX
2024-01-25 21:02:03.914 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 0
2024-01-25 21:02:03.914 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages in iCloud ‣ INBOX
2024-01-25 21:02:03.914 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in iCloud ‣ INBOX
2024-01-25 21:02:03.915 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: Gmail ‣ INBOX
2024-01-25 21:02:03.924 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 2
2024-01-25 21:02:03.924 [com.c-command.SpamSieve] [LogMailFilterer] Found 2 unread messages in Gmail ‣ INBOX
2024-01-25 21:02:03.926 [com.c-command.SpamSieve] [LogMailFilterer] Already filtered IDs: 2
2024-01-25 21:02:03.926 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in Gmail ‣ INBOX
2024-01-25 21:02:03.927 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: Lia-Newmedia ‣ INBOX
2024-01-25 21:02:03.928 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 0
2024-01-25 21:02:03.928 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages in Lia-Newmedia ‣ INBOX
2024-01-25 21:02:03.929 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in Lia-Newmedia ‣ INBOX
2024-01-25 21:02:34.757 [com.c-command.SpamSieve] [LogMailFilterer] Filter mailboxURLs: [mailbox:/INBOX?accountName=iCloud, mailbox:/INBOX?accountName=Gmail, mailbox:/INBOX?accountName=Lia-Newmedia]
2024-01-25 21:02:34.758 [com.c-command.SpamSieve] [LogMailFilterer] Filter mailboxURLs: []
2024-01-25 21:02:34.759 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: iCloud ‣ INBOX
2024-01-25 21:02:34.760 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 0
2024-01-25 21:02:34.760 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages in iCloud ‣ INBOX
2024-01-25 21:02:34.760 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in iCloud ‣ INBOX
2024-01-25 21:02:34.761 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: Gmail ‣ INBOX
2024-01-25 21:02:34.771 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 2
2024-01-25 21:02:34.771 [com.c-command.SpamSieve] [LogMailFilterer] Found 2 unread messages in Gmail ‣ INBOX
2024-01-25 21:02:34.772 [com.c-command.SpamSieve] [LogMailFilterer] Already filtered IDs: 2
2024-01-25 21:02:34.772 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in Gmail ‣ INBOX
2024-01-25 21:02:34.773 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: Lia-Newmedia ‣ INBOX
2024-01-25 21:02:34.774 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 0
2024-01-25 21:02:34.774 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages in Lia-Newmedia ‣ INBOX
2024-01-25 21:02:34.774 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in Lia-Newmedia ‣ INBOX
2024-01-25 21:03:06.758 [com.c-command.SpamSieve] [LogMailFilterer] Filter mailboxURLs: [mailbox:/INBOX?accountName=iCloud, mailbox:/INBOX?accountName=Gmail, mailbox:/INBOX?accountName=Lia-Newmedia]
2024-01-25 21:03:06.759 [com.c-command.SpamSieve] [LogMailFilterer] Filter mailboxURLs: []
2024-01-25 21:03:06.760 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: iCloud ‣ INBOX
2024-01-25 21:03:06.761 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 0
2024-01-25 21:03:06.761 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages in iCloud ‣ INBOX
2024-01-25 21:03:06.761 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in iCloud ‣ INBOX
2024-01-25 21:03:06.762 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: Gmail ‣ INBOX
2024-01-25 21:03:06.768 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 2
2024-01-25 21:03:06.768 [com.c-command.SpamSieve] [LogMailFilterer] Found 2 unread messages in Gmail ‣ INBOX
2024-01-25 21:03:06.770 [com.c-command.SpamSieve] [LogMailFilterer] Already filtered IDs: 2
2024-01-25 21:03:06.770 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in Gmail ‣ INBOX
2024-01-25 21:03:06.771 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: Lia-Newmedia ‣ INBOX
2024-01-25 21:03:06.771 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 0
2024-01-25 21:03:06.771 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages in Lia-Newmedia ‣ INBOX
2024-01-25 21:03:06.772 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in Lia-Newmedia ‣ INBOX
2024-01-25 21:03:37.158 [com.c-command.SpamSieve] [LogMailFilterer] Filter mailboxURLs: [mailbox:/INBOX?accountName=iCloud, mailbox:/INBOX?accountName=Gmail, mailbox:/INBOX?accountName=Lia-Newmedia]
2024-01-25 21:03:37.159 [com.c-command.SpamSieve] [LogMailFilterer] Filter mailboxURLs: []
2024-01-25 21:03:37.159 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: iCloud ‣ INBOX
2024-01-25 21:03:37.161 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 0
2024-01-25 21:03:37.161 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages in iCloud ‣ INBOX
2024-01-25 21:03:37.161 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in iCloud ‣ INBOX
2024-01-25 21:03:37.162 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: Gmail ‣ INBOX
2024-01-25 21:03:37.200 [com.c-command.SpamSieve] [LogMailFilterer] Call AppleScript subroutine unflagMessages: 0.03s
2024-01-25 21:03:37.204 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 1
2024-01-25 21:03:37.204 [com.c-command.SpamSieve] [LogMailFilterer] Found 1 unread messages in Gmail ‣ INBOX
2024-01-25 21:03:37.206 [com.c-command.SpamSieve] [LogMailFilterer] Already filtered IDs: 1
2024-01-25 21:03:37.206 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in Gmail ‣ INBOX
2024-01-25 21:03:37.206 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: Lia-Newmedia ‣ INBOX
2024-01-25 21:03:37.207 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 0
2024-01-25 21:03:37.207 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages in Lia-Newmedia ‣ INBOX
2024-01-25 21:03:37.208 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in Lia-Newmedia ‣ INBOX
2024-01-25 21:04:08.757 [com.c-command.SpamSieve] [LogMailFilterer] Filter mailboxURLs: [mailbox:/INBOX?accountName=iCloud, mailbox:/INBOX?accountName=Gmail, mailbox:/INBOX?accountName=Lia-Newmedia]
2024-01-25 21:04:08.758 [com.c-command.SpamSieve] [LogMailFilterer] Filter mailboxURLs: []
2024-01-25 21:04:08.759 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: iCloud ‣ INBOX
2024-01-25 21:04:08.760 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 0
2024-01-25 21:04:08.760 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages in iCloud ‣ INBOX
2024-01-25 21:04:08.760 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in iCloud ‣ INBOX
2024-01-25 21:04:08.761 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: Gmail ‣ INBOX
2024-01-25 21:04:08.770 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 1
2024-01-25 21:04:08.771 [com.c-command.SpamSieve] [LogMailFilterer] Found 1 unread messages in Gmail ‣ INBOX
2024-01-25 21:04:08.772 [com.c-command.SpamSieve] [LogMailFilterer] Already filtered IDs: 1
2024-01-25 21:04:08.772 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in Gmail ‣ INBOX
2024-01-25 21:04:08.772 [com.c-command.SpamSieve] [LogMailFilterer] Begin filtering: Lia-Newmedia ‣ INBOX
2024-01-25 21:04:08.773 [com.c-command.SpamSieve] [LogMailFilterer] Unread database message identifiers: 0
2024-01-25 21:04:08.773 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages in Lia-Newmedia ‣ INBOX
2024-01-25 21:04:08.773 [com.c-command.SpamSieve] [LogMailFilterer] Found 0 unread messages not yet filtered in Lia-Newmedia ‣ INBOX
It seems to be saying that it is checking your Gmail inbox, but that it’s not finding any new messages there to filter. This could be because the messages are not marked as unread or because they were received before the time when you first used or activated the Check inboxes for new messages not sent to Mail extension feature.
If you would like to troubleshoot this further, please contact me via e-mail and we can take a closer look at your setup.
Hi Michael,
Yes, I would most certainly like to pursue this further as I see scads of new emails Marked unread that have come in within the last couple of days and today. I would really like to get to the bottom of it and get it working better as so far I am still going to be required to do a lot of deleting and so forth which is exactly what I’m trying to avoid, spending hours each week deleting spam.
Please let me know what’s next!
Les
Hi Michael,
Under Apple mail > Settings > Extensions, SpamSieve extension was NOT checked; I’ve checked now per some well-hidden instructions I found.
That’s correct, yes??
Thanks,Les
Please contact me via e-mail.
Yes, it should usually be enabled. I’m not sure what you mean by “well-hidden”—it’s right in the setup instructions.
