I am not able to apply tags at the bottom of the screen when EF is maximised, the selectable tags scroll outside of the screen as in the attached vid. Is this a known issue?
Bildschirmaufnahme 2020-11-03 um 19.16.07
Typing the tags should work, but, yes, there is a known issue with the auto-complete menu and the tags bar. It should be popping up above the text field when near the bottom of the screen. I filed a bug with Apple, but as they don’t seem to be fixing this, my plan is to reorganize the window so that the tags aren’t at the bottom. A potential workaround, if you want the auto-completion in this situation, is to use the Batch Change command.
Thanks, I am also getting used to the tag cloud - a really mighty instrument - , but as I am currently cleaning up a huge collection of items collected from Evernote, Devonthink and the Finder it’s far too tiny with a couple hundred tags. So I will go with the batch change.
