Unfortunally Automator doesn´t use “user tags”
Is there a posibility to add those ones?
Is there a plan to automate those actions with EF?
I plan to add an EagleFiler Automator action that can set tags. However, you can do it today via an AppleScript action in Automator. For example:
on run {input, parameters}
tell application "EagleFiler"
import files input tag names {"tag 1", "tag 2"}
end tell
return input
end run
There is also a command-line utility for manipulating tags on files before they are in EagleFiler.
