Spamsieve 2.9.24 OSX- 10.11.6 on an aging iMac.
The combination ⇧+⌘+ S gives me “save to” and not “train as Spam” since moving to 10.11.6
Is there a workaround for this?
The menu item is of coure, still available.
Thanks.
Ozfrog
Thanks.
Ozfrog
Which mail program are you using? The keyboard shortcut is usually Control-Command-S, not Shift-Command-S.
I’m using Mail 9.3 Michael.
ctrl + ⌘ = S for Spamsieve?
That may be my problem
Later - tested your advice - perfect - thanks.
Thanks
