Show Battery Status in the Menu Bar
Hi there,
First of all, sorry for my terrible English.
Second, I have a V-MODA Crossfade 2 Wireless, and as you can see, in my iPhone X I’m able to see the Battery Status, however, even if I set that option on ToothFairy um my Macbook, It doesn’t show.
Is there anything that I can do to ToothFairy give me the Battery Status in the Menu Bar?
Thanks!
Best Regards
ToothFairy can only show the battery status for devices where macOS supports that, i.e. it is able to show the battery level in the Bluetooth pane in System Preferences. Unfortunately, macOS does not support as many devices as iOS does.
Ahhh, okay… thanks anyway!!
