Since I have moved to Mojave and the new version of EF 1.8.5, I find when I drag a URL link into EF from a browser it takes ages - get the spinning wheel - and then it sometimes works, not always.
What am I doing wrong?
Happy 2019.
Regards, Jack
Happy 2019.
Regards, Jack
I’m investigating a macOS 10.14 bug that can cause this. In the meantime, you should be able to work around it by dragging to the Dock icon instead of an EagleFiler window or by importing using the capture key, a bookmarklet, or the Share button.
I’ve worked around this macOS bug in EagleFiler 1.8.6b1.
