Smart Folder Actions
I have a smart folder that has a condition X. The smart folder has also an Action - moving to folder A. My assumption is that if a record meets condition X it would be moved to Folder A. That does not happen - I see the records in the smart folder, but they don’t move to Folder A. Is my understanding correct?
Daniel,
Smart folder actions are applied when you drag a record onto the smart folder, not simply because the record is displayed in the smart folder.
Thank you Michael, I see. If there were an option to have the Actions be performed on an object whenever it appeared in a smart folder I think it would make for some powerful functionality.
Daniel.
