Sorted Files not in numeric order
Every month, I import check images into an EF Folder. I start the name of each check with the check number. When I then sort by file (click on header), I expect the checks to be in numerical order. That’s the case for checks numbers less than four digits long, but not for larger numbers.
Here is the order in which the last five checks are shown in EF.
6483
2573625090
50191901
50251750
5702766
Is there any way to change this behavior?
Thanks for the report. EagleFiler is designed to do proper numeric (rather than alphabetical) sorting, but it looks like there’s currently a bug where this only works up to 5-digit numbers. I’ll get this fixed in the next version.
Thanks, Michael
Steve
It should be fixed in the new public beta of EagleFiler 1.8.13b2.
