Spam failed to move
I have the same problem since moving to El Captain: The filter works, but the “Train as Spam” - fails to move chosen email to Spam folder. Yes, the Rule is in place…
Spam failed to Move
I’m having the same problem. Here are the log excerpts:
10/5/15 2:22:22.583 PM adam[65227]: SpamSieve Apple Mail Plug-In [Train as Spam] Error Training: Mail got an error: Can’t get mailbox “INBOX” of account “Law E-Mail”.
10/5/15 2:22:53.647 PM adam[65235]: SpamSieve Apple Mail Plug-In [Train as Spam] Error Training: Mail got an error: Can’t get mailbox “INBOX” of account “Law E-Mail”.
10/5/15 2:32:49.561 PM Mail[65566]:
Loaded Mail Version 9.0 (3094)
OS X Version 10.11 (15A284)
Installed Bundles:
/Users/xxxx/Library/Mail/Bundles/MailActOn.mailbundle (3.2.1b1971)
/Users/xxxx/Library/Mail/Bundles/SpamSieve.mailbundle (1.8.3)
10/5/15 2:32:55.034 PM Mail[65566]: SpamSieve Mail Plug-In: Launching via launch agent failed.
10/5/15 2:32:55.228 PM SpamSieveHelper[65586]: Performance: Please update this scripting addition to supply a value for ThreadSafe for each event handler: “/Library/ScriptingAdditions/SIMBL.osax”
10/5/15 2:34:14.461 PM adam[65631]: SpamSieve Apple Mail Plug-In [Train as Good] Error Training: Mail got an error: An error of type 8 has occurred.
From what I’ve seen, errors like this are caused by two interacting bugs:
Updating to Mac OS X 10.11 sometimes causes Mail to create a duplicate IMAP account where one didn’t exist before. The new account is marked as inactive, so you wouldn’t ordinarily see it unless you go to the Accounts section of Mail’s Preferences window.
If you have two accounts with the same name (the Description field), Mail’s AppleScript support (which SpamSieve uses to move trained messages) can get confused and report that error when the script tries to reference a message in the inbox.
The workaround is to either rename or delete the inactive account so that all of your accounts then have unique names.
Thank you. I removed disabled and redundant accounts, which fixed half the problem. Now messages in the Inbox marked as “Spam” are moved to the Spam folder; however, messages in the Spam Folder marked as “Good” remain in the Spam Folder. The console generates an Error 8 message. Any suggestions?
My spam is not able to be trained.
I have visited Console, and have the following message:
7/10/2015 8:10:57.221 AM Arthur[652]: SpamSieve Apple Mail Plug-In [Train as Spam] Error Training: Mail got an error: Can’t get mailbox “INBOX” of account “…”.
I do not have any duplicated or redundant accounts, and SpamSieve is picking up ‘normal’ spam, I am just not able to train as spam.
I have not heard of anyone else in that situation. Please send in a screenshot of the Accounts section of Mail’s preferences and tell me the name of the account in the error message. Thanks!
Thanks for sending the screenshot. It looks like the account mentioned in the error message is a duplicate. There are an active POP account and an inactive IMAP account that have the same name. There are also two other pairs of duplicated accounts. I recommend that you rename the inactive ones to have “Inactive” in their Description field so that Mail doesn’t get confused.
