I am getting the same spam every day, with my account as sender. I have set up everything as stated in the documentation for Eudora users:
In filters I’ve checked Use Mac OS X Address Book and Exclude my addresses and I’ve run “Update address book ‘me’ Card”. (Although I don’t use the system Address Book for anything else). Eudora’s junk threshold is set to 50. I have no "notify user” filters.
I’ve told SpamSieve this is junk many times (just about every day).
Two things are strange however:
I don’t find this spam in the log (Library/Logs/SpamSieve/SpamSieve Log.log), so I figure the problem is that SpamSieve never sees these messages (although it does see a lot of them every day and is then very accurate).
My false negatives folder is apparently not working. It seems to be in the right place (Library/Application Support/SpamSieve/False Negatives) because when I ask SpamSieve to open it from Preferences (Save false negatives to disk -> Show) it does show it, but there’s nothing in it although I’ve used the “Junk” command many times in the last few weeks. Actually, there was stuff in it, but all dated back to 2005, so I emptied it.
There are two types of spam that get through (or rather that are not seen): one (always the very same, no subject, no sender name, just my address and a short message, always the same one, with a url, always the same one. The other uses my address but has a different name every time. Some spams using my account are seen and filtered, so I can’t figure out what’s wrong…
Mac OS X 10.4.9
Eudora 6.2 registered version
SpamSieve 2.6.1 (plugin version 1.0.5 in Eudora)
Thanks for any help.
EllenH
