SpamSieve 2.9.2
Version 2.9.2 of SpamSieve is now available. This is a free update that includes the following changes:
  • Improved compatibility with the forthcoming OS X 10.8 Mountain Lion.
  • The recommended condition for the Apple Mail rule is now Every Message
    rather than Message Type Is Mail. SpamSieve will auto-update your rules at launch on Mac OS X 10.7 if Mail is running. - SpamSieve is better at detecting a certain type of tricky spam message.
  • Worked around an OS bug that prevented SpamSieve from properly analyzing some message attachments.
  • False negative files now have the .eml extension so that they work with Quick Look, etc.
  • The Setting Up a Spam Filtering Drone section of the manual has been updated with simpler instructions for Apple Mail and new instructions for setting up a drone using Microsoft Outlook 2011.
  • Added the Using a Spam Mailbox on the Server section of the manual (for Apple Mail).
  • Updated various graphics for retina displays.
  • If the Apple Mail plug-in cannot be installed due to a folder ownership problem, SpamSieve will now ask for an administrator password to try to fix the folder for you.
  • Reverted to version 1.2.3 of the Growl SDK to avoid problems with high CPU usage, internal errors, and crashes.
  • Improved SpamSieve‚Äôs reporting of unexpected errors as well as script errors from Apple Mail.
  • SpamSieve no longer responds at all to certain invalid commands. This should work around an OS bug that could lead to crashes.
  • The crash reporter can now make recommendations for you based on the contents of the crash log.
  • Added a link to the forum in the Help
    menu.
SpamSieve 2.9.2 works with Mac OS X 10.4 through 10.8 and requires an e-mail client. Older versions are available for older operating systems. For information about previous releases of SpamSieve, please see the version history.
