Version 2.9.48 of SpamSieve is now available.
- Added support for Apple Mail on the forthcoming macOS 12.3. We recommend updating SpamSieve before updating macOS. SpamSieve 2.9.48 should automatically update the installed version of its Apple Mail plug-in, and the plug-in should stay enabled. However, if you don’t see the SpamSieve commands in Apple Mail’s Message menu, be sure to choose Install Apple Mail Plug-In from the SpamSieve menu and to enable the plug-in.
- Improved error reporting for the software updater.
SpamSieve 2.9.48 works with macOS 10.9 through 12.3 and requires an e-mail client. Older SpamSieve versions are available for older versions of macOS. In-depth information about SpamSieve is available in the manual.
