  • SpamSieve will show a warning in the Settings window if checking the inboxes is disabled or if an inbox was skipped for filtering because it contained too many messages.
  • SpamSieve will now warn you in the Settings window if you have Apple Mail mailboxes selected for filtering but filtering is disabled.
  • The cutoff date for checking the inboxes is now based on when you first launched a version of SpamSieve with this feature or when you toggled the setting.
  • Fixed a bug where certain settings migrated from SpamSieve 2 would make it show that trained messages would be moved to Junk but actually they would not be moved.
  • If SpamSieve skips filtering a mailbox because it’s too large, this will now be reported in the Log window and also called out in Settings ‣ Apple Mail ‣ Setup.
  • SpamSieve is better at reporting whether a server filter thought that a message was spam.
  • The menu item for opening the Settings window is now called Settings, even on older versions of macOS, as having it called Preferences was confusing people following the instructions in the manual.
  • In the Select Mailboxes to Filter… sheet, the special mailboxes are now sorted to the top, like in Apple Mail.
  • When Mail reports an error finding inbox messages to check, SpamSieve now reports the account name.
  • When the same error occurs when communicating with Apple Mail or Outlook, SpamSieve now only logs it once per hour.
  • Fixed a bug where viewing a partially deleted log entry could cause a crash.
  • Improved SpamSieve’s launch time by preloading scripts in the background.
  • Updated the Dutch, French, German, Spanish, and Swedish localizations.
  • Many sections of the manual have been revised or updated.
SpamSieve 3.0.1 is now available.
