- Tried to work around an issue where Apple Mail could be slow when using fast filtering if it hadn’t yet fully downloaded a message.
- Work around a Core Data bug that could cause a crash when saving the corpus.
- Updated the Danish, Dutch, French, Japanese, and Spanish localizations.
Fester1
3
Just did a direct download of the “b5” beta, and so far CPU use is now normal (fingers crossed…). For the last few weeks with the latest Sonoma beta, I thought that the Apple mail app was in itself using much higher than normal CPU, but narrowed it down to spamsieve. Thanks for the new Betas, any problems, I’ll let you know. I know Apple has been changing lots with Sonoma. Falls under the category of "as soon as you know, the answer, they change the question ".:-).
SpamSieve 3.0.2 is now released, so I recommend updating from the beta version.
