  • SpamSieve no longer triggers the “find devices on local networks” prompt on macOS 15. It never needed that access, anyway.
  • SpamSieve is now built with Xcode 16 and the macOS 15 SDK. We do not expect this to cause any visible changes, but it’s possible that some macOS frameworks will now behave differently when running SpamSieve on macOS 15.
Previously: Beta 1.
