SpamSieve 3.0.6b4 Public Beta
  • Worked around a bug in macOS 15 where sometimes the system help viewer wouldn’t open to the right help page. SpamSieve will instead open help files in the user’s Web browser.
  • Fixed an issue where SpamSieve could get confused if you corrected a mistake but the mail server had changed the message data in between the prediction and the training.
  • Updated the Korean and French localizations.
Previously: Beta 3.
