- It’s now possible to select more than 1,000 log entries at once.
- Added the Apple Mail - Block Reply-To sample script.
- Fixed a bug where in rare cases SpamSieve did not find the correct sender or recipient names or addresses from a message.
- Fixed a bug where the Train SpamSieve allowlist, Train SpamSieve blocklist, and Train Bayesian classifier settings were hooked up to the wrong checkboxes in the Settings window.
- Fixed a bug where custom training keyboard shortcuts esoteric preferences didn’t work for numbers and some other keys.
