SpamSieve 3.2.1
SpamSieve 3.2.1 is a free update for those who have already purchased the SpamSieve 3.0 upgrade. If you’re using SpamSieve 2 and haven’t upgraded yet, the easiest way is to first let SpamSieve install the new version. At launch, it will show the Purchase window, and you can click the Check Upgrade Options button to get the upgrade discount without having to enter your old serial number.
Normally, SpamSieve will automatically offer to update you to the new version. There are also instructions for updating on this page. SpamSieve 3.2.1 is compatible with macOS 10.13 (High Sierra) through macOS Tahoe 26 and is recommended for all customers using those versions of macOS. Older versions are also available for macOS 10.12 (Sierra) and earlier.
Microsoft Outlook
  • As previously mentioned, Microsoft will be temporarily removing Outlook’s support for AppleScript (and, thus, SpamSieve) on November 1. It is scheduled to return in December. In the interim, SpamSieve can continue to filter your mail if you set up your mail accounts and SpamSieve in Apple Mail. This will also keep the spam out of your inbox in Outlook, and if you enable the Train messages in TrainSpam and TrainGood setting, you can still train SpamSieve from within Outlook. There’s more information about all of this in the End of Support for Legacy Outlook section of the manual.
Apple Mail
  • Worked around a bug in macOS Tahoe 26, affecting some customers with POP accounts, that could cause hangs or prevent messages from moving to the Junk mailbox.
  • Updated the Train messages in TrainSpam and TrainGood section of the manual.
  • Fixed a bug where remote training would log (harmless) errors for POP accounts.
  • The Mail extension will now retry if it gets a timeout error communicating with SpamSieve.
  • Improved the Mail extension’s error reporting.
  • Worked around a macOS bug that could cause a hang when logging Mail-related errors.
  • SpamSieve is better at finding the inbox when running in Spanish.
macOS Tahoe 26
  • Worked around a change where macOS would keep trying to re-add the SpamSieve icon to the menu bar even if you’d turned the Show menu bar icon feature off.
  • Fixed a bug where the Dock icon didn’t adapt to different themes.
  • Worked around a macOS bug that could cause a crash at launch.
  • Improved the layout of the Software Update… sheet.
General
  • The status colors for the menu bar icon when training and filtering now use the same colors as SpamSieve’s Dock icon and Apple Mail.
  • Worked around a Help Viewer bug on macOS 14.
  • Tried to work around a crash updating the Statistics window if the database is damaged.
  • The diagnostic report shows additional information about fragmentation of SpamSieve’s database files and the Apple Mail Junk mailbox configuration.
  • Fixed the icon margins in the legacy ICNS file and documentation.
  • Updated the Swedish localization.
