SpamSieve 3.2.2b2 Public Beta
  • Microsoft has extended support for Legacy Outlook for another year, so SpamSieve no longer warns about the transition to New Outlook in the Settings ‣ Outlook ‣ Setup window. The End of Support for Legacy Outlook and Turning Off New Outlook sections of the manual have been updated accordingly.
  • When SpamSieve classifies a message using an allowlist or blocklist rule, the Log window now shows when that rule was created and whether it was created by the user or by SpamSieve’s auto training.
  • Worked around a problem where macOS would not report to SpamSieve that Apple Mail or Microsoft Outlook was the frontmost app, so SpamSieve did not enable the training commands for those mail clients.
  • Worked around an AppleScript bug in macOS 10.14 that could cause a crash.
  • Fixed some threading bugs with undoing changes to rules.
  • Reduced the Swift bridging overhead when parsing message address lists.
  • Added some debug logging to investigate cases where the Settings window is being shown inappropriately.
Previously: Beta 1.
Checking SOFTWARE UPDATE shows there is no newer version. I am running 3.2.2b1.
I think that’s fixed now. Please try again.
OK now—guess it was just a long queue for the update. Color this one solved.
