SpamSieve 3.3.1
SpamSieve 3.3.1 is a free update for those who have already purchased the SpamSieve 3.0 upgrade. If you’re using SpamSieve 2 and haven’t upgraded yet, the easiest way is to first let SpamSieve install the new version. At launch, it will show the Purchase window, and you can click the Check Upgrade Options button to get the upgrade discount without having to enter your old serial number.
Normally, SpamSieve will automatically offer to update you to the new version. There are also instructions for updating on this page. SpamSieve 3.3.1 is compatible with macOS 10.13 (High Sierra) through macOS 27 (Golden Gate) and is recommended for all customers using those versions of macOS. Older versions are also available for macOS 10.12 (Sierra) and earlier.
  • Made various optimizations to reduce SpamSieve’s memory use when processing large amounts of data.
  • Made various optimizations to speed up searching by word in the Corpus and Log windows.
  • When the same message is filtered more than once, the earliest prediction is now used for accuracy statistics calculations.
  • The Copy Allowlist/Blocklist Addresses script has been updated and now uses a dedicated script property to make it much faster when you have lots of rules.
  • Accessing rules and words via AppleScript is much faster and now works with very large amounts of data, which previously would have triggered an AppleScript error about running out of memory.
  • Added the Traveling Away From Your Mac section of the manual and a link from the Settings window.
  • Improved the tooltips in table views.
  • Date and number formatting now automatically updates when the Mac’s locale changes.
  • Improve handling of Unicode in filenames
  • Improved the diagnostic report.
  • Worked around a Core Data bug that could prevent the database from being saved.
  • Worked around a Core Data bug that could cause a crash when calculating accuracy statistics if the database was damaged.
  • Worked around a Core Data bug that could cause spurious errors when pruning the log.
  • Fixed a bug where Settings ‣ Apple Mail ‣ Setup would continue warning about Check inboxes for new messages not sent to Mail extension being disabled even after you had enabled it.
  • Fixed crash opening certain windows on macOS 10.13.
  • Made various updates for Xcode 27 and macOS 27.
  • Updated the German localization.
