- Made further changes to try to work around a crash when reading the corpus database.
- Tried to work around a bug where Apple Mail failed to move Gmail messages out of a training mailbox.
- The About SpamSieve window can now be used when the trial period is over.
- The Software Update… command will now help you check for an update if the trial period is over.
- Improved the following section of the manual:
Previously: Beta 3.
