SpamSieve 3.3.3b1 Public Beta
  • Updated SpamSieve to account for changes in macOS 27.3 related to the Full Disk Access setting. If you’ve already installed SpamSieve and given it Full Disk Access, it will keep working as before. For new installations, it is now possible to grant it Files & Folders access to Apple Mail instead. This is described in the Granting Full Disk Access section of the manual.
  • Due to a bug in macOS 27, SpamSieve’s menu bar icon may not be clickable if the mail client is in full screen mode. You can avoid this problem by exiting full screen mode or by hiding SpamSieve’s Dock icon. When in full screen mode, you can still train SpamSieve from SpamSieve’s Dock icon or by using the keyboard shortcuts.
  • Added a Swift SDK to make it easier for mail client developers to integrate support for SpamSieve.
  • If SpamSieve can’t filter new messages because it’s missing Automation access, the error log entry now includes a help link.
  • SpamSieve’s training and filtering hotkeys now work with a Greek keyboard layout.
  • Improved SpamSieve’s PDF reader tool.
  • Improved the error reporting when message data is missing.
  • Copying from the log now shows which rules are locked.
  • Added a workaround for a problem where Apple Mail is unable to move Gmail messages to the inbox.
  • Fixed a bug where Apple Mail filtering could be slower or fail if SpamSieve launched while Mail was still rebuilding its database.
  • Fixed a problem where old Apple Mail messages could be refiltered if you upgraded to a new Mac.
  • Fixed a bug where SpamSieve would incorrectly refilter old messages in mailboxes that were manually selected for filtering if they were marked as unread and SpamSieve did not have Full Disk Access.
  • Fixed a regression where adding a new rule didn't clear the search field.
  • Future-proofed the split view code.
