SpamSieve commands not appearing in Eudora menu
I recently reinstalled Eudora 6.2.4 on my Mac OS 10.5.8. I tried reinstalling the SpanSieve plugin several times, each saying successful, but the commands do not appear in the Eudora menu. Where do I go from here?
What, specifically, are you expecting to see that you’re not seeing? Did you follow all of the installation steps?
Problem Solved!
Michael Tsai, you’re the best! I resolved the problem per your instructions. (Following the basic setup instructions turned out to be not such a bad idea after all). Thanks a heap!
Richard
Problem solved.
Thanks, Michael. The problem has been solved. You’ve been a great help.
