Hello Michael
for unknown reason SpamSieve has started giving me these messages
sometimes I get:
SpamSieve has deactivated Mail rule
and if I quit Mail & SpamSieve and relaunch Mail I get
SpamSieve has activated Mail rule
Getting annoying
Hello Michael
sometimes I get:
Getting annoying
This is normal if the plug-in is not enabled or if Mail is not running. However, a few people have also reported this happening in other circumstances. I’m trying to figure out what’s causing this. Could you tell me whether you are launching SpamSieve before Mail or whether it seems like Mail is taking more than a few seconds to launch?
Hello
the plugin is enabled since my last update to Mojave
and was working normally
SpamSieve launches after Mail, automatically, I see it briefly appear in the dock
is Mail taking a few longer seconds to launch? if so it would me milliseconds, as I do not see any longer bouncing in the dock
It does not happens all the time, but yesterday was at every launch I had a SpamSieve alert ( deactivated or activated )
Mail version 12.0 (3445.100.39)
SpamSieve 2.9.33
Mojave
OK, this sounds like a different issue that what some others have reported. Please click this link to enable some debug logging. Then, the next time this happens, please send in a diagnostic report.
I’ll do
thanks
I made some changes in the SpamSieve 2.9.34b1 public beta that should help with this.
It did, thank you Michael
It does it again , diagnostic report sent
This should be improved in SpamSieve 2.9.34b3.
Same Problem
I am having the same issue. I have successfully installed SpamSieve, given it the appropriate permissions, etc.
Every time I quit and restart Mail, when SpanSieve loads I get the same deactivation message as above. If I quit and restart again (or just quit and restart SpamSieve), the plug-ins get reactivated. I am using SpamSieve version 2.9.34b3.
–>Steve
Right after the next time this happens, please send in a diagnostic report.
Same Problem
I have the same problem. Diagnostic Report is sent.
Looking forward for a solution.
Thanks for the report. I think the SpamSieve 2.9.34 public beta version will work much better for you.
Same problem but I followed the link to install SpamSieve version 2.9.34b3. Got the error message again, as soon as Mail opened.
So, from my UX, no change.
M
SpamSieve 2.9.34b4 is now available. Please try that.
SAme Problem
I have this same problem. I am running SpamSieve 2.9.34.
Bob K.
I read past the suggestion you mention and deleted DataVaults; this solved my problem. Actually I have found Mojave to be very slo-o-o-ow on my old iMac. Deleting Mail’s DataVaults sped up startup (after login), my web browser, mail, and other apps. I’m not sure I understand enough to know why deleting that (Mail) folder sped my system up so much but the difference is noticeable, very obvious. Thanks! I was ready to downgrade to High Sierra.
I made some more changes in the SpamSieve 2.9.35b1 public beta that should help with this.
