Spamsieve timed out to Apple Mail. Tried to look at log. Got the follow error when trying to bring up logs,
Anyone know how to fix this?
Thanks
Rand
Thanks
Rand
The SQLite error number 11 means that a database file is corrupt. If you choose Help ‣ Open Error Log and look in the (other) log or if you use the Save Diagnostic Report command in the Help menu and send me the report file, as described here, there will be more information about which file is damaged and we can advise you further.
