Not working with Catalina 10.15 (19A526h)
After downloading and installing 2.9.37b1, I get this message when trying to choose SpamSieve.mailbundle in Mail preferences:
Incompatible Plug-ins Disabled
Mail has disabled the following plug-ins:
Contact the makers of these plug-ins for versions that are compatible with Mail 13.0.
Still can’t install
Trying to install, get this message: “SpamSieve was unable to open the file ‘SpamSieve-2.9.37b3.dmg’. Please click Check Now and try again, or go to <https://c-command.com> to download the update yourself.”
Because SpamSieve 2.9.36’s Software Update “Download & Install” command doesn’t work on macOS 10.15, it’s best to update to the beta version of SpamSieve before installing the macOS 10.15 beta on your Mac. You can also click the “Download” button and do the install manually, according to the instructions in the Read Me file.
Beta 4 causing Mail to crash?
Since updating to SpamSieve 2.9.37b4 I have been getting multiple random crashes. I can’t say it’s SS causing it for sure, but it lines up with my updating of the plugin. Anyone else having issues?
How Do I Obtain The Beta directly from your website?
The Update function cannot open the beta and says to download it directly from your site. I am using the developer Beta of Catalina.
Deleting Spam identified by SpamSieve
It appears i am having a lot of difficulty in deleting my emails that have been identified by SpamSieve as spam. First the apple script fails to work failing on an error code or time out of an event. Second, when I attempt to delete these emails directly, they seem to delete but in all cases they return to my deleted folder. I can’t delete from the SpamSieve folder, I can’t deleted from my Trash folder, I can’t delete from my Junk folder. I am on the latest version of DiscardSpam apple script and on the beta version of SpamSieve, and the Beta Version of Apple MacOS Catalina.
Prior to this, I had to turn off SpamSieve, delete the messages manually, then turn it on again. Once, I had to uninstall SpamSieve, then reinstall.
Please submit technical support questions via e-mail, rather than posting here. Please include information about the error codes/messages from the AppleScript, how many messages were in the Spam mailbox at the time, etc.
However, since you’re also having trouble directly deleting messages using Mail, it sounds like a Catalina bug that you should report to Apple. SpamSieve doesn’t have any impact on operations that you do manually in Mail.
