Hi there. I’m finding my SS3 is marking a lot as blacklisted.
Is the Spamsieve Rule supposed to be implemented with SS3?
Please be more specific. Is this something that you’re seeing in the Log window? Did you expect something different to happen?
If you are using Apple Mail, there should be a SpamSieve rule in Mail if you’re using the plug-in setup but not if you’re using the extension setup.
So SS3, extension setup. I’ve turned off the SS rule. It was turned on.
Keeping an eye on it. Seems like it’s working.
