I typically use at least two different computers, one for work and one at home, and was wondering if there was any consideration towards syncing settings & data across multiple systems via iCloud, Dropbox or something else?
Failing sync, is there a way to script a corpus export?
There’s currently no way to sync (except the Contacts list). The SpamSieve and Multiple Macs page has information about different possible setups and which files to copy if you wanted to “sync” them yourself. You should not export the corpus; rather, quit SpamSieve and then copy the actual corpus file.
