If I try to add a tag in the tag bar at the bottom of the screen between two existing tags, when I hit “enter” to accept a completion the tags is entered but following tags are removed.
Is this a (known) bug?
I think this is due to an OS bug. I’m trying to find a workaround, but in the meantime I think you’ll have better luck if you use Spacebar (or Right-arrow) to accept the completion rather than Enter or Return.
Done in EagleFiler 1.1.2.
