Tagging feature request
Would it be possible to assign tags to folders so that when an item is placed inside a folder, the folder’s tags are automatically assigned to that item?
Thanks for the suggestion. I’m working on something like that.
EagleFiler 1.4 lets you assign actions to smart folders so that tags can be assigned (or removed) when you drop a record onto the smart folder.
