You could write an AppleScript that always imports into a certain folder and adds certain tags, save it as a droplet, and then drag and drop files onto the droplet to import them.
You could make smart folder and set the destination folder and tags in its action. Then, after importing files, you could find them Recently Added and drag them onto the smart folder to apply its action.
