Why do the tags in the inspector change order when selected?
Is there any way to turn that behaviour off?
If you have it sorted by the first column, the tags that are assigned to the selected record(s) will always sort to the top. So the order will change when you change the selection. If you have it sorted by tag name, the order will remain constant.
Ah, gotcha.
Thanks
