Tags column in record panel
I set a tag for an item. If I search for that tag the item shows up, but the tag doesn’t show in the tags column in the records panel. Shouldn’t it?
doug
No. To have it show up in the Tags column you must give the tag an abbreviation. If you want to see tags that don’t have abbreviations, you need to make the Tag Names column visible.
Aha. Perfect. Thanks!
doug
