Tags in Inspector
Hi!
Im testing Eaglefiler and especially like its ability and way to assign tags. I mostly use tags to assign keywords and sometimes end up with five or six tags for one entry. Is it possible to view all of these tags in the inspector without maximizing the inspector window? In my inspector window the tags appear all in one long line which never gets broken and there seems to be no way to insert a line break.
Birgitt
If you make the Info inspector a little taller, you will be able to drag the bar that separates the tags and the notes in order to allow multiple lines for the tags. Unfortunately, there is a bug which prevents the tags from wrapping to utilize multiple lines. I will send you a pre-release version of EagleFiler that fixes this.
Fixed in EagleFiler 1.1.4.
