Tags that I enter in the Info Inspector do not stick… They disappear after I close and then re-open the window… Tags entered via the Tags section below the Viewer do show up in the Info Inspector… What am I missing?
Thanks…
Thanks…
Sorry, this is a bug that was introduced in a recent update. For now, you’ll need to Tab to another field or click on another window in order to get changes to the Tags field in the Info inspector to stick. I’ll fix it in 1.3.4.
This is fixed in EagleFiler 1.3.4.
