Is it possible to annotate folders?
I then to think in nested folder terms and would like to import existing folders of project files. I can’t figure out a way of putting a note that defines the folders contents rather than editing individual files. -
Are there examples somewhere of how other people use EagleFiler?
This seems to be a very deep program with lots of options. Are there any blog posts, writeups out there of how others have integrated EagleFiler into there workflow? -
Is it possible to create archive dvds of Libraries?
One possible use I can see is as away of bringing together project resources, final files, archived emails and then burning the Library file to external media as a way of archiving projects. Sensible? Possible? A better way?
Thanks in advance.
