thunderbird: stats, log and corpus empty
i installed spamsieve for my thunderbird yesterday, trained it with some messages, but the stats, log and corpus are empty
What am i doing wrong?
log:
Launched: 2.6.1
Date: 2007-04-12 09:36:41 +0200
Launched: 2.6.1
Date: 2007-04-12 09:45:50 +0200
Launched: 2.6.1
Date: 2007-04-12 10:53:37 +0200
stats:
Filtered Mail
0 Good Messages
0 Spam Messages
0 Spam Messages Per Day
SpamSieve Accuracy
0 False Positives
0 False Negatives
100.0% Correct
Corpus
0 Good Messages
0 Spam Messages
0 Total Words
Rules
32 Blocklist Rules
6 Whitelist Rules
Showing Statistics Since
11-04-2007 09:36
Which version of Thunderbird are you using? Do you see the SpamSieve plug-in in the Extensions/Add-ons window? Did you enable the adaptive filter for all your accounts?
version 1.5.0.10
i see the plugin installed
and in junk mail controls i have adaptive filter enabled
Did you enable it for all the accounts and for Local Folders?
If you select a message and click the Junk button, does it get marked with the green junk bin symbol and moved to the Junk folder? If you mark a message as Not Junk, does it remove the junk symbol?
where do i set that?
yes, thats working ok
In Tools > Junk Mail Controls, you have to configure the settings that you want separately for each choice in the “Configure Junk Settings for” pop-up menu.
i cannot get it to work:
see here my settings:
http://84.245.10.117/Picture-1.jpg
http://84.245.10.117/Picture-2.jpg
http://84.245.10.117/Picture-3.jpg
http://84.245.10.117/Picture-4.jpg
http://84.245.10.117/Picture-5.jpg
both settings for local folders and my single email account are the same
i have used thunderbirds junk mail controls, maybe thats doing something wrong?
Aha, it looks like you’re using Mac OS X 10.2. SpamSieve’s Thunderbird integration requires 10.4.
yes i am…so no spamsieve for me?
Not with Thunderbird. All the other mail programs are supported back to 10.2, however.
