The following was posted on the ToothFairy blog:
Version 2.4.7 of ToothFairy is now available. ToothFairy is a Mac menu bar utility that lets you connect AirPods to your Mac with a single click or keypress. It also works with other Bluetooth headphones and with input devices such as mice, keyboards, and game pad controllers. You can see at a glance which devices are connected, as well as their battery levels. ToothFairy can also make music and videos sound better by using a higher quality codec for audio output.
[ul]
[li]Added support for Dark Mode on macOS 10.14.[/li][li]Revised various preferences text to improve clarity. For example:[/li][LIST]
[li]Global hotkey to switch connection is now Global hotkey to connect/disconnect.[/li][li]Hide dock icon (effect after next launch) is now Hide Dock icon (takes effect at next launch).[/li][li]Audio output only is now Improve sound quality by disabling audio input.[/li][li]Connection only mode is now Don’t disconnect when clicking icon or pressing hotkey.[/li][/ul]
[li]Fixed a bug where the Audio output only option didn’t work, causing AirPods to be inappropriately set as the system audio input device.[/li][li]Added the Save Diagnostic Report button.[/li][li]Reduced the size of the application by having ToothFairy and its login item helper share the same copy of the Swift libraries.[/li][li]Fixed the minimum widths of the OK buttons.[/li][li]Reformatted the text in the credits sheet with fonts, styles, and clickable links.[/li][/LIST]
ToothFairy 2.4.7 works with macOS 10.11 through 10.14 and requires a Bluetooth device. For information about previous releases of ToothFairy, please see the version history.
