The following was posted on the ToothFairy blog:
Version 2.6 of ToothFairy is now available. ToothFairy is a Mac menu bar utility that lets you connect AirPods to your Mac with a single click or keypress. It also works with other Bluetooth headphones and with input devices such as mice, keyboards, and game pad controllers. You can see at a glance which devices are connected, as well as their battery levels. ToothFairy can also make music and videos sound better by using a higher quality codec for audio output.
- Added icons for AirPods Pro, Beats X, Microsoft Surface Earbuds, and an alternate icon for a pair of regular AirPods that are positioned symmetrically rather than offset.
- Adjusted the way battery levels map to gradations in the menu bar gauge.
- Added a button to the About
tab to open the ToothFairy manual. - Worked around a macOS bug that could prevent launching the app after using AirPlay. - Fixed a regression where the battery level wasn’t shown if it was exactly 100%.
- Modernized the localizations.
- Reduced the size of the app.
ToothFairy 2.6 works with macOS 10.11 through 10.15 and requires a Bluetooth device. For information about previous releases of ToothFairy, please see the version history.
If you enjoy using ToothFairy, please take a moment to review it on the Mac App Store, Product Hunt, or MacUpdate or to mention it on Twitter, Facebook, or your own site. We’d really appreciate it.
