ToothFairy 2.7.5
Version 2.7.5 of ToothFairy is now available.
  • Improved the battery status indicator on macOS 12 Monterey.
  • Improved the How can I turn off Automatic Device Switching? section of the manual.
  • Added French localization.
  • ToothFairy now declares notch compatibility for the new MacBook Pros.
ToothFairy 2.7.5 works with macOS 10.11 through 12.0.1 and requires a Bluetooth device. In-depth information about ToothFairy is available in the manual.
hey, 2.7.5 is crashing for me on launch on Monterey 12.0.1
I have a hang report that I’m happy to send over privately if that helps
I believe ToothFairy 2.7.6 works around the bug in macOS Monterey that can cause this hang.
