ToothFairy has been updated to version 2.8.6. This is a free update that is recommended for all ToothFairy owners. You can update to the latest version from the Mac App Store or Setapp. ToothFairy 2.8.6 works with macOS 10.13 through macOS 15.
- Improved the Improve sound quality by disabling audio input from device feature. When using multiple Bluetooth headphones/speakers, if you connect a new device, ToothFairy will no longer set the audio input to another device that you told it not to use, even if that device had been manually chosen (by you or another app). Instead, ToothFairy will try to select the built-in microphone or a previous device to ensure the best sound output quality.
- Worked around a macOS bug where a Bluetooth device would connect but a notification was never sent to ToothFairy. This could make the progress indicator in the menu bar keep spinning.
- Worked around a macOS bug where a Bluetooth device would connect but macOS would continue to tell ToothFairy that it was not connected. This could make the icon in the menu bar show the wrong status or keep showing the progress indicator.
- Fixed a crash that could occur when trying to disconnect from a device when the Don’t disconnect when clicking icon or pressing hotkey option was enabled.
- Replaced the battery status label in the Settings window with a help button that leads to more information.
- Made some changes to prevent ToothFairy from triggering local network privacy prompts.
- The diagnostic report now includes information about the app’s logs, the crash logs folder, and components that could cause AppleScript errors.
