I’d like to know if there is a way to train an email without opening it. Something like a right-click on the email in the list and then train. Currently, there is no command for doing this in the popup.
If you are worried about Web bugs, it’s probably best to disable the display of remote images because it’s easy to view messages by accident. And then there would be no reason not to train in the normal way.
That said, you could set up remote training, and then you would be ale to train by moving messages to the TrainSpam mailbox, which can be done from the contextual menu or by dragging and dropping a message that’s not selected.
Yes, I was worried about the nasty things that can be in these emails and are triggered when opened. I’ll try turning of the loading of remote images, but remote training might be the way to go. Thanks.
