I don’t think the Spam mailbox inside the Junk mailbox will be found by the “Train as Spam” command or by the “Remote Training” script. If you know how to write scripts, you could modify the script to support whatever layout you want. However, I recommend using the standard layout so that you are able to easily take advantage of future updates to the script.
